ermanmaster
communication in an ongoing printing process
hi everyone
I'm taking a long print a part right now. but I did forget set the retraction setting. Can I send this setting to the printer in an ongoing printing process?
Re: communication in an ongoing printing process
Assuming you're using standard retractions rather than firmware defined retractions, then no there would not be a way to update this during an ongoing build.
ermanmaster
S3D-Jake wrote: Thu Mar 24, 2022 11:05 am Assuming you're using standard retractions rather than firmware defined retractions, then no there would not be a way to update this during an ongoing build.
Thanks for answer
how my i do firmware defined retractions ?
Marlin's implementation utilizes G10 and G11 gcode commands to retract and unretract respectively.
https://marlinfw.org/docs/features/fwretract.html
