Ender 5 Plus with creality silent board start script
Posted: Tue Mar 29, 2022 10:55 pm
So I'm having this issue with my ender 5 plus with creality silent board upgrade. when ever I do a mesh level in script between g29 or a M420 s1 it does not register my layer 1 temp. I can give it command (M109 S215 T0) and will change the temp at least but wont just take from program the first layer temp. also after mesh my heated bed was turning off had to add that back in. so what code should be used for mesh leveling on simplify3d? If anyone could please help and either edit my code or tell me correct codes to use. Thanks below is my script all I want it to be able to do is do a mesh level at the start and heat to layer one bed and nozzel temp. last would be a purge line a like the double pass
; Ender 5 Plus Custom Start G-code
G28 ;Home
M109 S[extruder0_temperature]; set extruder temperature and wait for temp after bed leveling
M140 S{material_bed_temperature_layer_0} ; Set Heat Bed temperature
M190 S{material_bed_temperature_layer_0} ; Wait for Heat Bed temperature
M104 S160; set extruder temperature and wait for temp after bed leveling
M420 S1 ;BLTOUCH mesh generation
M109 S215 T0; set extruder temperature and wait for temp after bed leveling
M117 Purge Extruder
G1 X0.1 Y20 Z4.3 F5000.0 ; Move to start position
G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
G92 E0; reset extruder
G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
G1 X0.6 Y20.0 Z0.3 F5000.0 ; Move to side a little
G1 X0.6 Y200 Z0.3 F1500.0 E30 ; Draw the second line
G92 E0 ; Reset Extruder
; End of custom start GCode
M117 Printing...
G28 ;Home
M117 Purge Extruder
M117 Printing...
