Corkscrew problem
Posted: Tue Jun 21, 2022 12:09 pm
Hello,
I am new to S3D and hoping someone can give me a pointer here. I cant get he corkscrew setting to work no matter what I try.
I always end up with a z-seam. The toolpath is continuous but it jumps up in one same place rather than smoothly increasing in Z. Does the corkscrew actually produce seamless results or is that just how it works in S3D?
I have a simple cylinder on top of a solid base (different process assigned to base). I want the cylinder to be spiralized/vase-mode/corkscrew. I am ticking the corkscrew(vase mode) box and tried the 'merge all outlines' box in slicing behaviour too. Perimeter shell is set to 1. 0 top/bottom layers. I tried both outline direction options. Start points set to optimise. Infill 0.
Any help or info would be very much appreciated.
