MakerBot 1 dual process setting doesn't have extruder choice
Posted: Fri Jul 22, 2022 5:18 pm
by raylo32
I have a new to me MakerBot 1 dual extruder clone and loaded the profile. But the process setup window does not allow a choice of which extruder to use. It lists both toolheads and shows the settings for each, but nowhere has a box to select which one you want to use. The temp for the right shows 215 for PLA and the left 0. But what if I want to use the left instead? I have tried the MakerBot 2 dual and that DOES have a box to select which toolhead and it seems to work. But that one has a different x/y stepper drive ratio (88.5 vs 94.1) such that the prints come out ~6% small.
Re: MakerBot 1 dual process setting doesn't have extruder choice
Posted: Fri Jul 29, 2022 9:13 am
by Njoro
Hi
First you need to import the 2 parts you want to print, go to "Tools", "Dual Extrusion Wizard" a new window will open showing "Right and Left Extruder".....
