jim_medeiros
Linux install .run problem
Have downloaded and unzipped the 64-bit Linux install onto a 18.04 distribution.
When I run the .run file (after unzipping in the download directory), I get the following error:
sudo ./Simplify3D-4.1.2-linux-x64-installer.run
./Simplify3D-4.1.2-linux-x64-installer.run: 1: ./Simplify3D-4.1.2-linux-x64-installer.run: Syntax error: Unterminated quoted string
Any obvious fix?
jim_medeiros
Re: Linux install .run problem
I should also state that this is on an NVIDIA Jetson Nano (which is ARM based) -- minimum requirements state an Intel processor, but is there a strict Intel limitation?
parallyze
jim_medeiros wrote: Sat Jul 23, 2022 6:22 pm I should also state that this is on an NVIDIA Jetson Nano (which is ARM based) -- minimum requirements state an Intel processor, but is there a strict Intel limitation?
No, AMD/Intel doesn't matter on a pc as long as it is using the x86-64(AMD64) instruction set. ARM is a completely different architecture
and would require emulation, like Rosetta2 on current Apple Silicon machines.
