Changing a layer flow rate in a script??
Posted: Tue Sep 20, 2022 3:37 am
There is one feature that I really like in CURA where you can increase the flow rate on the first layer to get a better "smoosh" and a smoother surface. S3D only allows you to change the line width, that REALLY isn't the same thing. There are a variety of hidden scripting changes that you can make at various points in an S3D print.
Has anyone found a way to increase the first layer flow rate? Or, perhaps even better, arbitrarily change the flow rate at any layer?
be well,
be well,
