Stuttering curves on Makerbot Replicator Z18
Posted: Tue Nov 22, 2022 1:17 pm
I have recently switched from slicing on the MakerBot cloud platform to slicing with S3D, but I noticed that the curves are not printing as well as when sliced on MakerBot cloud. It appears that, when sliced with S3D, the printer travels through the curved section with a stuttering movement of short segments instead of a continuous curve as it does when the model was sliced on MakerBot cloud. Print sliced with S3D also takes significantly longer to print. Is there any setting I can modify on S3D that will fix the problem? I tried the ArcWelder plugin, but I don't think it works with .makerbot output format.
These are images of the two test prints printed on the same printer (MakerBot Replicator Z18, firmware version 2.6.2)
Makerbot Cloud Print: https://imgur.com/0qccfEU
S3D: https://imgur.com/UHbCQsI
Comparison: https://imgur.com/nbtXdG3
The Setting used on both prints:
2400mm/min outline speed,
single outline with 0% infill (vase mode),
0.2mm layer height,
200 °C,
Thanks a lot!
0.2mm layer height,
200 °C,
Thanks a lot!
