Bug: Machine size in options
Posted: Fri Nov 28, 2014 7:02 pm
by UKIan
In machine settings I change the size of my build area to be 180x180X120. This will remain in effect for between 10 seconds and a few minutes before something triggers it to reset.
Re: Bug: Machine size in options
Posted: Sat Nov 29, 2014 4:22 pm
by KarlW
In the process settings on the G-code tab there is an option to update machine definitions. If there is a check mark in the box, your settings will be changed back to whatever is set there. This might be the problem you are seeing.
Posted: Sun Nov 30, 2014 4:35 pm
by UKIan
KarlW wrote:In the process settings on the G-code tab there is an option to update machine definitions. If there is a check mark in the box, your settings will be changed back to whatever is set there. This might be the problem you are seeing.
Sounds promising, I'll report back
