Hi there,
I have DM556T drivers (https://www.oyostepper.com/goods-112-Di ... Motor.html)
and I'd like to get NEMA 34 series motors for them. I have these two in mind and I'm not sure if I could get the stronger one considering the drivers.
https://www.oyostepper.com/goods-401-Ne ... ozin-.html
https://www.oyostepper.com/goods-510-E- ... Wires.html
Or do you think that even the weaker one is on the edge and I should go even lower?
Controlled from PC via LPT port. It will be powered by a 36VDC switching power supply. Designed to drive the axes of a CNC router with a floor plan of 0.7 x 1.2 m (2x Y axis, 1x X axis, 1x Z axis), ball screws with a pitch of 5 mm. Wood "alloys" will be machined
