yep. i used that a lot and they also munged up groupings since hiding an object DOES NOT stop the process from slicing it (which it should)
now it takes extra clicks when I print it ALWAYS highlights the whole group and I don't WANT to highlight the whole group so now I have to click select NONE and then select the one process I want to print. Grrrr
Uncle Jessy wrote: ↑Fri Dec 16, 2022 8:42 pm
Also use this one a lot and hope it gets added back in. Great when importing lots of files
I too used that feature all of the time. For now, you can "replicate" the functionality by grouping your models
and moving them off the print bed. Then slice as normal. S3D will complain about models being off the build
surface but it's ok to ignore the warning.
