Page 1 of 3
No checkmark to hide the objects in V5
Posted: Wed Dec 14, 2022 1:44 pm
by DanceM
There is no checkmark to hide the objects in V5.
Re: No checkmark to hide the objects in V5
Posted: Wed Dec 14, 2022 9:54 pm
by nerys
yep. i used that a lot and they also munged up groupings since hiding an object DOES NOT stop the process from slicing it (which it should)
now it takes extra clicks when I print it ALWAYS highlights the whole group and I don't WANT to highlight the whole group so now I have to click select NONE and then select the one process I want to print. Grrrr
Posted: Fri Dec 16, 2022 8:42 pm
by Uncle Jessy
Also use this one a lot and hope it gets added back in. Great when importing lots of files
Posted: Wed Dec 21, 2022 1:41 pm
by bolsoncerrado
+1 to bring it back!
Can't believe the vast amount of stuff they removed that was superuseful!!
I'm starting to regret on the upgrade damnit!
Posted: Wed Dec 21, 2022 1:58 pm
by gearsawe
+1
bring back. kind of looks like there is a space for it. looks more like an oops bug.
Posted: Thu Dec 22, 2022 2:05 am
by Al1deR
+1
Posted: Sun Dec 25, 2022 5:28 pm
by gearsawe
is this counted as a feature if it is removed? HA!
Posted: Sun Dec 25, 2022 8:56 pm
by DrD
Uncle Jessy wrote: ↑Fri Dec 16, 2022 8:42 pm Also use this one a lot and hope it gets added back in. Great when importing lots of files
I too used that feature all of the time. For now, you can "replicate" the functionality by grouping your models
and moving them off the print bed. Then slice as normal. S3D will complain about models being off the build
surface but it's ok to ignore the warning.
Posted: Mon Dec 26, 2022 7:43 pm
by dsiegfried
This one is easy. Go into Edit Process Settings, click on Select Models, then select only the models you want to slice.
Posted: Tue Dec 27, 2022 10:29 am
by kyleamorgan
+1
