zemlin
Process groups not working to change settings in all group members
I only tried this on one setting. Was playing around and wanted to see what the adaptive layer height would do in one of my builds.
I grouped all the processes and then checked the adaptive layer height in one process. It only changed it in that process. By V4 process grouping workflow it should have changed that setting in all processes. Have not explored the extent of this.
UPDATE - I did change something else in a process group and it updated in all processes ... might be something specific with adaptive layer height.
Re: Process groups not working to change settings in all group members
I just ran a test here, but it correctly changed the setting I modified across all of the grouped processes. Can you share more details about the exact setting you changed when the problem happened? Are you able to get the problem to happen repeatedly?
