Page 1 of 2
[FIXED] Changing the scale of a model does not maintain the scale percentage value V5
Posted: Thu Dec 15, 2022 8:12 am
by jbenw07
Scaled percentage changes back to 100% after moving to another model.
Example: I have 5 models on the build plate and want to print them all at 5% scale increments to test for sizing. If I change each one to 90%, 95%, 105%, 110% and leave one at 100%, and I go back to each model, the scale now reflects 100% for every single one, although the scaled measurements are saved. I would like to still be able to see what percentage I scaled each one at, since it's easier to document scaling than it is to document X, Y and Z.
Re: Changing the scale of a model does not maintain the scale percentage value V5
Posted: Fri Dec 16, 2022 2:37 am
by jfkansas
I just posted about the same thing. On top of that supports seem to change scaling/model size a little even though there are no supports outside of the model.
Definitely would be nice to have this back to v4 style. If I change a model to 100.8 in x/y, sometimes I back this off to 100.6. Now I have to reset the model and then change to 100.6.
Posted: Fri Dec 16, 2022 7:51 am
by zemlin
I need to run some test parts before I'll consider running V5 for my manufacturing, so hadn't gotten into scaling parts - but that's for the heads-up - that could be a serious issue for me.
I also noticed that using the drag tool does not update the scaling numbers either.
Posted: Fri Dec 16, 2022 11:08 am
by VitHudecek
This is a big deal for me too. I do use scale for testing models and this is something that you have to write original numbers on a paper to have them saved..
Posted: Sat Dec 17, 2022 10:42 am
by SHoutzager
I am having the exact same scaling issues. If I scale up a part by a percentage and then deselect it, it will snap back to 100% but the dimensions will stay the same. :?
Also I want to close out the scaling window and keep it docked. Do I have to undock that window to be able to close it?
Posted: Sun Dec 18, 2022 6:35 pm
by gearsawe
This has come up in a a couple other threads now. and is a big deal for me too.
Posted: Tue Jan 03, 2023 5:59 pm
by M4nusky
+1
definitly a bug
Posted: Wed Jan 11, 2023 8:57 am
by DForbes
M4nusky wrote: ↑Tue Jan 03, 2023 5:59 pm +1
definitly a bug
Yep same here, found out the hard way by waisting a day chasing this around, what the hell man?
Posted: Thu Jan 12, 2023 4:02 pm
by jfkansas
definitly a bug
I don't think it is a bug, it is probably related to how S3d "connects" to a STL/3MF file for auto updating. It might be how that feature was designed to work. Maybe it could be refactored hold the percentage and orientation values like before.
Posted: Thu Jan 12, 2023 4:04 pm
by jfkansas
DForbes wrote: ↑Wed Jan 11, 2023 8:57 am
definitly a bug
Ya, best thing to do now is note what you scaled everything at. If need to change scaling, reset all transforms and then change the value to a new percent.
