3D Mouse Support
Posted: Thu Dec 15, 2022 2:50 pm
by dibor
Hello.
How to enable/configure 3D Mouse ?
Thank you.
Re: 3D Mouse Support
Posted: Fri Dec 16, 2022 10:42 am
by S3D-Jason
You shouldn't have to do anything special to enable it. Just install the 3Dconnexion drivers, plug in the mouse, then start S3D and the mouse should be automatically detected. If that doesn't work, try rebooting your computer first.
Posted: Fri Dec 16, 2022 12:51 pm
by dibor
Sorry, do not works in this way
Space mouse driver was installed before Simplify3D installation and works/worked with Fusion 360 application.
After installing Simplify3D I did reboot and 3D mouse doesnt works with Simplify3D
I also tried to add Simplify3D to the 3Dconnextion but nothing helps
Here MacOS 13.1and Space mouse Wireless, 3DxWare 10 version 10.7.4
Best Wishes.
Posted: Fri Dec 16, 2022 2:11 pm
by S3D-Jason
We have heard some reports of issues with the 3Dconnexion drivers on newer MacOS versions. It's possible that may be related. It would help to know if S3D users on MacOS 10.x are having issues with the 3D mouse as well, or if it's just happening on MacOS 11-13.
Posted: Sat Dec 17, 2022 2:46 pm
by dibor
Hello.
My Mac does not support older 10.x MacOS versions, so I cannot to check.
For now this is a bug in the v5
I hope yours developers can check and fix this a bug.
Best Wishes.
Posted: Tue Dec 20, 2022 2:23 am
by SweHogelid
My SpaceMouse Enterprise does not work either. Firmware 4.41
MacOS Ventura 13.1 - M1
Spacemouse driver 10.7.0, it works with F360, PrusaSlicer, Blender. (I can't get 10.7.4 to work with FreeCAD so therefor I use this older driver)
Posted: Thu Jun 22, 2023 12:23 am
by macjundi
It does work on the latest update...
I got it to work on my MacBookPro M1Max
You need to go to control panel, open the 3DConnextion panel, and choose add application from the pulldown menu
Select Simplify3D from the application folder
then it will work.
Posted: Thu Jun 22, 2023 11:48 am
by S3D-Jason
Yes, I believe this was addressed in one of our earlier 5.0.x released (see the release notes here:
https://www.simplify3d.com/products/sim ... ase-notes/)
