Model scaling percent resets to 100% after size change.
Posted: Fri Dec 16, 2022 2:34 am
by jfkansas
A frustrating and unwelcome change to how model scaling works. Took me a bit to figure this out. V4 always held the model scaling values. I set my x/y to 100.8% and it is nice to have a visual reference that the model is set to that. It now changes back to 100%, but the model retains the new size.
Re: Model scaling percent resets to 100% after size change.
Posted: Fri Dec 16, 2022 4:00 pm
by zemlin
Yeah, that's a major PITA.
I won't be using V5 for production parts until that's fixed. I scale everything for dimensional accuracy and I NEED to know where things are at. Plus, you can't just reset scaling - you have to reset ALL transforms so if you parts are located on the bed ... too bad.
Make scaling stick, and put a reset button on scaling alone.
Posted: Fri Dec 16, 2022 8:44 pm
by Uncle Jessy
This is an issue with Scaling & Rotation values!
This is a significant issue for me and the app as I heavily rely on it retain that information vs being reset.
1. Using the input field change the Rotation value or Scale %
2. Use one of the new gizmo tools at the bottom of the screen to Rotate or scale
3. All of the values will be reset
Posted: Sun Dec 18, 2022 3:46 pm
by gearsawe
Yes please fix! retain the percent to what it was set to. and not reset back to 100% after it has been deselected and selected again.
need to know if a part was scaled appropriately to account for cooling shrink factors.
same goes for rotations!
Posted: Tue Dec 20, 2022 12:24 pm
by curlykid1
This really needs to be fixed ASAP
Posted: Sun Jan 08, 2023 8:12 am
by jstrom
Yes, this is an major issue for me as well. Please fix.
Posted: Sun Jan 08, 2023 6:00 pm
by Goochman
This is a major issue, please fix ASAP!!
