Temperatures Not Corresponding
Posted: Fri Dec 16, 2022 6:46 pm
by vic14
On Machine Control Panel / Accessories Controls, The Set temperatures doesn't correspond to actual temperatures, in the include pic, my set temperature is nozzle 240, Bed 80 it's not displaying that information correctly.
Re: Temperatures Not Corresponding
Posted: Sat Dec 17, 2022 3:23 pm
by S3D-Jason
The number on the left is the current temperature that the machine is reporting. The number on the right is the target temperature. They will frequently be different while the temperatures are rising or falling.
I believe the red dot on the far left just lights up once the temperature starts to get hot enough it would be dangerous to touch. So that should change based on the left number.
Posted: Sat Dec 17, 2022 5:24 pm
by vic14
The target temperature is not what i have set in the slicer!!! That’s the issue, it might correspond it might not, but the thermistors raise as they should according to the slicer settings.
Posted: Sun Dec 18, 2022 2:13 pm
by S3D-Jason
Those values don't change based on your process settings. They are just for manual control. You can enter whatever value you want. Typically I believe people use that for preheating or turning off the heaters when the machine is not in use.
In other words, your slicer settings determine the temperatures that are used during the print. The set point values in the Machine Control Panel are just the manual values you want to use when performing maintenance (changing filament, etc).
Posted: Sun Dec 18, 2022 2:39 pm
by vic14
Version 4.1.2 Starts with ZERO Set Point
Version 5 Starts with a 200 Nozzle, 60 Bed (I did not set that!!!!!)
It Doesn't Change until the nozzle or bed is almost operating Temperatures
png[/attachment][attaEchment=0]Screenshot 2022-12-18 142202.png[/attachment]
Posted: Mon Dec 19, 2022 9:35 am
by S3D-Jason
Oh, I think the issue is just that the actual input (the one you can type numbers into) is on the right instead of the left. Both V4 and V5 in your screenshots are both reporting the machine temperature as zero degrees.
Posted: Mon Dec 19, 2022 9:43 am
by vic14
are you on the S3D design team?
