[FIXED] v5 Dark Mode + MacOS Dark Mode - not usable
Posted: Fri Dec 16, 2022 8:40 pm
by Uncle Jessy
If you are trying to use v5 with Dark Mode enabled + MacOS Dark Mode or Auto Appearance setting you will not be able to clearly read text/fields
Re: v5 Dark Mode + MacOS Dark Mode - not usable
Posted: Sat Dec 17, 2022 3:31 pm
by S3D-Jason
Very odd! Do you mind sharing what MacOS version you are using? We had not seen this before on the Macs in our office, so it's possible we need to test on a specific version.
Posted: Sat Dec 17, 2022 6:42 pm
by jfkansas
I can report no issues with dark mode in app and macos. Maybe check your theme and display settings.Might have Macos overriding s3d text color.
Posted: Fri Jan 06, 2023 1:16 pm
by S3D-Jason
You need to restart S3D whenever you make a theme change. If you change from light to dark mode within S3D, I believe it already tells you to restart the software. If you change the Mac OS theme externally through System Preferences, you will need to restart S3D yourself before it looks correct.
In short - restart S3D whenever you change the theme and then it will look correct
Posted: Thu Jan 19, 2023 2:38 pm
by S3D-Jason
Version 5.0.1 was released with further improvements for this issue. In the past, you had to restart S3D after you changed the dark mode setting in Mac OS. Now, Version 5.0.1 should detect that changes automatically so that you do not need to restart the software. So the issue that was originally reported should now be resolved.
