Page 1 of 3
V5 - Defining Custom Infill Angles - Missing feature?
Posted: Sat Dec 17, 2022 1:07 pm
by VividCreative
V5 has moved a few things around and it seems also dropped a few features that where very useful
V5 seems to have dropped the ability to define multiple/consecutive infill angles - both for internal and external infills
V4 Screen shot
V5 Screenshot
However, the feature seems to still be honored by the V5.
If open a previous factory file created in V4, and then slice it in V5, the defined infill angles are kept in the resulting slice. But, if I make a change to the the angle setting in V5, the previously defines setting are lost
Team Simplify3D - Is it possible to bring this feature back, or was this simply an inadvertent omission?
Re: V5 - Defining Custom Infill Angles - Missing feature?
Posted: Sat Dec 17, 2022 2:27 pm
by S3D-Jason
Can you explain a bit more about what you're trying to do? You can still rotate the infill pattern in V5 using the rotation angle input that you circled.
Posted: Sat Dec 17, 2022 7:05 pm
by VividCreative
Sure – sometime with some of the parts that we manufacture we need to define the actual angles of the external infill pattern. We do this for a couple of reasons. Sometimes it's for a specific look, as we need the bottom most layer to align a certain direction and the top layer to align a different. Since we can not define top/bottom layer angles in S3D, this was an easy way around that.
In other instances, we use the ability to define a series of angels in a specific order to generate strength and rigidity in solid parts. For instance, the screenshot I included above was a way for us to introducing additional strength and rigidity part printed in PETG that was only 8 layers thick. Since PETG is generally more flexible filament the sequence of layers help us create a part that was more rigid in one direction while being stronger in the other.
IN this case a specific sequence of angles was able to achieve the result we needed
Posted: Sun Dec 18, 2022 1:59 pm
by S3D-Jason
As a potential workaround for now, you could use the Variable Settings Wizard to create different processes for the bottom 5 layers, middle, and top 5 layers. Then you can use the new "Aligned" infill pattern in V5 and define the exact angle that you want to use. This way you could align the angles of all 5 bottom layers to perfect match the part, and so on.
Posted: Sun Dec 18, 2022 8:06 pm
by studiokite
yes I also use this. generally i reduce the amount of material needed by using alternating infill 0deg and 90deg and dont print on each layer.
I then also use the 0 and 45 for the external infill settings. It is a bit strange that this feature was removed.
Posted: Sun Dec 18, 2022 8:14 pm
by studiokite
I Just noticed using an old factory file the infill settings are carried over but not the support.
I find alternating the support angle makes it stronger and better to build on.
Posted: Tue Dec 20, 2022 2:53 pm
by KarlW1000
Custom angles also work well with round parts. The images show how the infill is more even with V4 than V5 by using angles 45, -45, 0, 90. In V5 it is just 0 and 90 so even if they are rotated they are still 90 degrees apart and leaves the round part with less rigidity.
Posted: Wed Jan 18, 2023 4:39 pm
by studiokite
any updates s3d?
Posted: Thu Jan 19, 2023 6:12 am
by myprinter
I need to know too.
Posted: Thu Feb 09, 2023 9:46 am
by scobob
Same here
