Smooth Bottom - Small Part (IMAGE UPDATED)
Posted: Sat Dec 17, 2022 5:40 pm
by tivowatcher
I am trying to print a very small part (about 1.5 cm tall x .75 cm wide). See attached.
I assume I have the extruder settings fouled up as I cannot get a nice flat/smooth bottom. Instead I can easily see the lines of filament running inside the walls.
Any thoughts on how to spread the filament out so I can a nice smooth surface on the bottom?
https://ibb.co/41YqZTK
Re: Smooth Bottom - Small Part (IMAGE UPDATED)
Posted: Wed Jan 04, 2023 10:42 pm
by tivowatcher
Any thoughts on this?
Posted: Thu Jan 05, 2023 6:11 am
by S3D-Jason
It looks like the extruder may be starting too far away from the bed. Maybe try setting your global Z-axis offset to -0.05mm?
See the "Nozzle starts too far from the bed" section on this page:
https://www.simplify3d.com/resources/pr ... o-the-bed/
Posted: Thu Jan 05, 2023 10:13 am
by gwhite
Have you calibrated your extrusion multiplier?
If that is all set, you can set up a process for the first layer with a higher extrusion multiplier to fill things in a bit better.
