Limited Global G code Offset issue
Posted: Sat Dec 17, 2022 9:55 pm
by Advall
Max offset one can enter is 99.99 mm.
So how can I print say only the top 25 mm of a item that is say 200 mm high when max global g code offset is 99.99 mm?
Maybe there is a different way?
Any suggestions are very welcome.
Re: Limited Global G code Offset issue
Posted: Sun Dec 18, 2022 2:03 pm
by S3D-Jason
You should not use the gcode offsets for that. Instead, click the Custom Zones button at the bottom and enable the "Start printing at Z height" option.
