Page 1 of 2
Connecting to DUET 2 WiFi?
Posted: Sat Dec 17, 2022 11:20 pm
by Mogal
Anyone successful connecting directly to a duet?
I can't seem to figure it out.
Thanks.
Re: Connecting to DUET 2 WiFi?
Posted: Sun Dec 18, 2022 3:48 pm
by Stout
There does not seem to be a direct link to Duet cards :? At least SDJake wrote that in a thread I can't find.
I use several different Duet3D cards in my printers and it's a NoNo for me to upgrade to v5 when Prusa and other slicers handle it so smoothly.
Edt:
Found it....
S3D-Jason wrote: ↑Sat Dec 17, 2022 4:02 pm I don't think the Duet board was listed as one of the supported Wifi printers on the release notes, so I'm guessing there's just new code required to support that board. The team is very open to feature requests right now, so certainly vote for it on the Feature Request subforum if you want to see it added!
Posted: Sun Dec 18, 2022 8:02 pm
by joel
As far as I have gotten is when testing the connection over wifi, it seems to connect but then errors out saying javascript needs to be enabled.
Posted: Mon Dec 19, 2022 9:23 am
by S3D-Jason
joel wrote: ↑Sun Dec 18, 2022 8:02 pm but then errors out saying javascript needs to be enabled.
Would you mind posting a screenshot of this error? I'm not sure it's one we have seen before.
Posted: Mon Dec 19, 2022 2:17 pm
by joel
Here is the spew I get, this is running 3.4.5 on the duet. The failure shows up on each attempt,
We're sorry but Duet Web Control does not work properly without JavaScript enabled. Please enable it to continue
Attempting connection at 192.168.1.69:3000...
Connection refused. Make sure the device is turned on and the connection details are correct.
SENT: GET http://192.168.1.69/command GETPRINTERSTATUS
SENT: GET http://192.168.1.69/api/v1/system
READ: <!DOCTYPE html><html lang="en" translate="no"><head><meta charset="utf-8"><meta http-equiv="X-UA-Compatible" content="IE=edge"><meta name="viewport" content="width=device-width,initial-scale=1,user-scalable=0"><meta name="google" content="notranslate"><!--[if IE]><link rel="icon" href="/favicon.ico"><![endif]--><title>Duet Web Control</title><link href="/css/app.23e90265.css" rel="preload" as="style"><link href="/js/app.d0ad7b20.js" rel="preload" as="script"><link href="/css/app.23e90265.css" rel="stylesheet"><link rel="icon" type="image/png" sizes="32x32" href="/img/icons/favicon-32x32.png"><link rel="icon" type="image/png" sizes="16x16" href="/img/icons/favicon-16x16.png"><link rel="manifest" href="/manifest.json"><meta name="theme-color" content="#2196f3"><meta name="apple-mobile-web-app-capable" content="yes"><meta name="apple-mobile-web-app-status-bar-style" content="black"><meta name="apple-mobile-web-app-title" content="Duet Web Control"><link rel="apple-touch-icon" href="/img/icons/apple-touch-icon-152x152.png"><link rel="mask-icon" href="/img/icons/safari-pinned-tab.svg" color="#2196f3"><meta name="msapplication-TileImage" content="/img/icons/msapplication-icon-144x144.png"><meta name="msapplication-TileColor" content="#000000"></head><body><noscript><strong>We're sorry but Duet Web Control does not work properly without JavaScript enabled. Please enable it to continue.</strong></noscript><div id="app"></div><script src="/js/app.d0ad7b20.js"></script></body></html>
Connection failed.
Posted: Mon Dec 19, 2022 2:37 pm
by Mogal
I get the same/similar error.
Attempting connection at 192.168.68.68:3000...
Connection failed.
SENT: GET http://192.168.68.68/command GETPRINTERSTATUS
SENT: GET http://192.168.68.68/api/v1/system
READ: <!DOCTYPE html><html lang="en"><head><meta charset="utf-8"><meta http-equiv="X-UA-Compatible" content="IE=edge"><meta name="viewport" content="width=device-width,initial-scale=1,user-scalable=0"><!--[if IE]><link rel="icon" href="/favicon.ico"><![endif]--><title>Duet Web Control</title><link href="/css/app.e2701cec.css" rel="preload" as="style"><link href="/js/app.56671d18.js" rel="preload" as="script"><link href="/css/app.e2701cec.css" rel="stylesheet"><link rel="icon" type="image/png" sizes="32x32" href="/img/icons/favicon-32x32.png"><link rel="icon" type="image/png" sizes="16x16" href="/img/icons/favicon-16x16.png"><link rel="manifest" href="/manifest.json"><meta name="theme-color" content="#2196f3"><meta name="apple-mobile-web-app-capable" content="yes"><meta name="apple-mobile-web-app-status-bar-style" content="black"><meta name="apple-mobile-web-app-title" content="Duet Web Control"><link rel="apple-touch-icon" href="/img/icons/apple-touch-icon-152x152.png"><link rel="mask-icon" href="/img/icons/safari-pinned-tab.svg" color="#2196f3"><meta name="msapplication-TileImage" content="/img/icons/msapplication-icon-144x144.png"><meta name="msapplication-TileColor" content="#000000"></head><body><noscript><strong>We're sorry but Duet Web Control does not work properly without JavaScript enabled. Please enable it to continue.</strong></noscript><div id="app"></div><script src="/js/app.56671d18.js"></script></body></html>
Connection failed.
Posted: Tue Dec 20, 2022 3:26 am
by S3D-Jason
Oh, I think that is actually a javascript message being sent by the Duet board. It's trying to display a webpage that says "We're sorry but Duet Web Control does not work properly without JavaScript enabled. Please enable it to continue."
That's a pretty confusing message. I'm not sure why javascript would be required to do a simple http GET command...
Posted: Wed Dec 21, 2022 4:46 am
by tooponn
hellodear.in
tea tv apk
Posted: Sun Mar 26, 2023 1:31 am
by dmbgo
Any solutions for this?
Posted: Sun May 14, 2023 6:07 am
by dindo59
hello, i have the same problem, simplify 5.1.1 , duet2 wifi , connection doesnt work, PLEASE can FIX ? can help US ? thank you
