[FIXED] V5 MakerGear M2 E Stop Not Working
Posted: Mon Dec 19, 2022 11:33 pm
Just upgraded to V5, and the E-Stop button in Machine Controls no longer works. Per the communication log, it is sending M112. Printer seems to ignore it, does not reboot, or stop any in progress actions.
MakerGear M2 V$ (24V). Works fine in Simplify3D V4.1.2
See Log Below, expect reboot after M112.
Attempting connection at \\.\COM3...
READ: start
READ: echo:Marlin 1.0.0
READ: echo: Last Updated: Dec 30 2016 22:17:50 | Author: (none, default config)
READ: Compiled: Dec 30 2016
READ: echo: Free Memory: 4137 PlannerBufferBytes: 1232
READ: echo:Hardcoded Default Settings Loaded
READ: echo:Steps per unit:
READ: echo: M92 X88.88 Y88.88 Z1007.70 E471.50
READ: echo:Maximum feedrates (mm/s):
READ: echo: M203 X500.00 Y500.00 Z25.00 E25.00
READ: echo:Maximum Acceleration (mm/s2):
READ: echo: M201 X4000 Y4000 Z100 E10000
READ: echo:Acceleration: S=acceleration, T=retract acceleration
READ: echo: M204 S2000.00 T3000.00
READ: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
READ: echo: M205 S0.00 T0.00 B20000 X8.00 Z0.40 E5.00
READ: echo:Home offset (mm):
READ: echo: M206 X0.00 Y0.00 Z0.00
READ: echo:PID settings:
READ: echo: M301 P25.89 I1.94 D86.53
READ: echo:SD init fail
READ: ok T:0.0 /0.0 B:0.0 /0.0 T0:0.0 /0.0 T1:0.0 /0.0 @:0 B@:0
Connection successful!
SENT: M114
SENT: M27
READ: ok T:32.5 /0.0 B:20.0 /0.0 T0:32.5 /0.0 T1:20.3 /0.0 @:0 B@:0
READ: X:0.00Y:0.00Z:0.00E:0.00 Count X: 0.00Y:0.00Z:0.00
READ: ok
READ: Not SD printing
READ: ok
SENT: M105
SENT: M27
READ: ok T:34.2 /0.0 B:19.8 /0.0 T0:34.2 /0.0 T1:20.0 /0.0 @:0 B@:0
READ: ok
SENT: M112
READ: ok
SENT: M105
SENT: M27
READ: ok T:34.0 /0.0 B:19.7 /0.0 T0:34.0 /0.0 T1:20.1 /0.0 @:0 B@:0
READ: ok
READ: start
SENT: M114
SENT: M27
READ: ok
READ: ok
SENT: M105
SENT: M27
READ: ok
SENT: M112
READ: ok
SENT: M105
SENT: M27
READ: ok
