g-code for slowly cooling of heated bed
Posted: Mon Dec 01, 2014 3:38 am
Hello again.
I have a qhestion to the g-code experts...
I have build an thermal housing for my mendelmax 2.5 because i only print ABS mainly big abs parts. ( 240mmx310mmx10mm)
During the printin i have NO warping but when the print is over and the bed cools down i get a little bit warping and thats not good because the parts have to be straight....
now i want to correct my g-code that the bed cools down from
110 degrees to 80 degrees and stays there for 30 minutes
then from 80 degrees to 60 degrees and stay there for 30 minutes
from 60 to 40 and stays there for 30 min
and at least to normal room temeperature ( bed heating off )
my g-code at moment is this :
G 28 XY
M104 S0 ; turn off extruder
M140 S0 ; turn off bed
M84 , disable motors...
Pls can anyone help me to change my gode to the request i need ??
thanks for all
Ps: this is my Printer in the housing
G 28 XY
thanks for all
