V5 cannot run two instances (or more) at the same time reliably
Posted: Tue Dec 20, 2022 7:31 pm
I used to have two to three instances of S3D with V4.x, each working with a different machine so that I could run separate parts for a build at the same time.
This no longer works.
First off: Windows 10 pro on i5 system with 32GB RAM.
How to duplicate:
start S3D, click on Edit Process Settings, and select a profile, note what it is - change something, then "OK" the edit.
start another instance of S3D V5 (right click on the S3D icon on the task bar).
Select Edit Process Settings and change to another profile, then close the edit.
Go back to the first instance of S3D, Edit process settings, You will see the profile you chose in the second instance, not the first.
This happens sporadically, it is not reliable in its behavior. Sometimes it settles down and lets you run both, I am not sure what I do differently to get to this point.
be well,
DLC
How to duplicate:
be well,
DLC
