hyppyayo
Infill diameter
Hello,
I got a REP2X, i'd like to know if there is an option to increase the infill diameter.
thanks
Nico
Re: Infill diameter
The extrusion width for infill will be the same as your perimeters. If your looking to cut some time then you can use the sparse infill setting which will print infill every 2 or 3 layers that are double or triple thick.
