Support defaults not sticking
Posted: Wed Dec 21, 2022 11:38 am
When creating automatic supports and setting the support parameters those parameters are reset back to defaults when starting or reloading a project.
Very annoying. I always use pillar size 1mm and angle 60 which in V4 would be assigned to the process and become the default. Now every time a project is opened, those parameters need to be set manually. They should either be sticky parameters or part of a process like they used to be.
Teamwork,
Steve
Teamwork,
Steve
