MisterG65
Double click and no model on default screen
Good Evening
When I double click an STL (macOS 10.14) S3D opens, but nothing appears in the main window. I can "Prepare to Print" without issues, but I cannot alter anything before that
Ideas please?
Re: Double click and no model on default screen
Very odd. If you open S3D manually and then import that same STL file, does everything work?
MisterG65
Yes... no issues that time. Also should the last selected Process appear on opening? I'm getting empty there, too, no matter which method of opening I use
Thank you
