Version 5 moves origin
Posted: Thu Dec 22, 2022 10:30 pm
by mpd352
Just installed version 5.
Simplify3d v5 shows the model centered on the build surface:
Once imported to Octoprint it is offset to the lower right corner. Settings were imported from v4 and worked.
Re: Version 5 moves origin
Posted: Sat Dec 24, 2022 2:56 pm
by S3D-Jason
If you print the part, does it actually end up in the middle of the bed?
Posted: Mon Jan 02, 2023 10:04 am
by DJLesman
I'm having the same issue. I used to have the origin in the middle of my printbed for IDEX reasons.
In V5 I am unable to find the "Origin offset" setting as it was present in V4 in Tools>Options>Machine.
Edit after first post: I found it in the process settings under the "Output" tab.
