KeyboardWarrior wrote:jimc wrote:not sure if this is what your looking for but on the top, goto mesh then calculate volume. if gives you the cm3 of the model.
I believe he's asking for cm3 if filament used. Which since the filament diameter is calculated, as well as mm of filament used, would simply be multiplying those two by 3.14 and you'd have mm^3 or the volume of filament used, which is easily convertible to cm^3.
correct me if I'm wrong, but I believe this calculation is missing a couple steps and will only yield mm^2
- mm.PNG (1.97 KiB) Viewed 4158 times
pi *
r^2 * h = volume of a cylinder ; the length of plastic used is the height, you forgot we have diameter of filament not radius
so I believe the proper formula will be:
- mmm.PNG (2.8 KiB) Viewed 4158 times
