EdoNork
V5 Half a second pause on perimeters between changes
My Wanhao Duplicator 4D makes about half a second pauses on perimeters between features.
For example, a rounded rectangle:
- First line, pause, arc, pause, second line...
- On a hole: first circle, pause, second concentric circle, pause...
Internal walls and infills don't have those pauses.
V4 never did that pauses.
Any configuration mistmatch?
I'm using my V4 configurations.
Re: V5 Half a second pause on perimeters between changes
Are you printing over USB or from the SD card?
It's possible the pauses could be retractions, so I would also listen to the extruder motor to see if you hear it moving during the pause, or check the gcode for extra retractions in those areas.
