Print time remaining
Posted: Tue Dec 27, 2022 5:42 pm
by ldsanders
Version 5. This is probably right in front of my eyes, but, where do I locate the amount of print time left while the object is printing? I see the Progress Bar on the Machine Control Panel. I'm looking for the estimated time left in hours and minutes. Thanks!
Re: Print time remaining
Posted: Wed Dec 28, 2022 6:03 am
by Donmanfredo
I have exactly the same problem. Since I've been using version 5.0, no print time is displayed on the 3D printer. Time 0
Posted: Fri Dec 30, 2022 12:07 pm
by S3D-Jason
Donmanfredo wrote: ↑Wed Dec 28, 2022 6:03 am
I think that might be a different issue. I think the original post was about the time display in S3D, not on the printer itself.
What printer are you using?
Posted: Tue Jan 03, 2023 9:35 pm
by wirlybird
I just noticed today on one of my printers that the remaining time is at "0" for the whole print.
I'll keep an eye on other printers to see if they do this also.
This is on the printer and not on the S3D control panel.
Posted: Wed Jan 04, 2023 9:00 am
by S3D-Jason
wirlybird wrote: ↑Tue Jan 03, 2023 9:35 pm
Some printers try to parse the print time from the gcode file comments, so if the machine isn't showing the time, you may want to check the bottom of the gcode file to make sure the time is listed there (it should be the last 5 or so comment lines in the file)
Posted: Wed Jan 04, 2023 9:06 am
by cote
Hi. Simplify3D V5 changed the comment from "Built time" to "Build Time" (note the capital T). In the case of Klipper firmware, it is enough to mess things up when it comes to parsing the slicer estimate.
Posted: Wed Jan 04, 2023 9:21 am
by wirlybird
S3D-Jason wrote: ↑Wed Jan 04, 2023 9:00 am
I will check that. The printers I have noticed this on so far do ok with time using V4. Just as an FYI.
Posted: Fri Mar 10, 2023 6:17 pm
by ldsanders
I just noticed that V 5.02 has print time "Remaining:" below the progress bar in the Machine Control Panel!
Thanks for that info!!!
