Import Directory
Posted: Tue Dec 27, 2022 11:38 pm
by airlid
Program needs to remember previous "Import" directory path, just like V4
Re: Import Directory
Posted: Thu Dec 29, 2022 5:18 pm
by waterbornewarrio
Similarly, on export. Export build file to disk defaults to the same folder as the model file. But perhaps one saves gcode files in a different folder than model files?
Posted: Fri Dec 30, 2022 12:26 pm
by S3D-Jason
waterbornewarrio wrote: ↑Thu Dec 29, 2022 5:18 pm Export build file to disk defaults to the same folder as the model file. But perhaps one saves gcode files in a different folder than model files?
I think you can already make that change by going to Tools > Options, and then changing the "File Selection Behavior" to "Remember a unique directory for each separate file type". Then it will remember a separate directory for models vs gcode files.
Posted: Fri Dec 30, 2022 2:46 pm
by waterbornewarrio
S3D-Jason wrote: ↑Fri Dec 30, 2022 12:26 pm I think you can already make that change by going to Tools > Options, and then changing the "File Selection Behavior" to "Remember a unique directory for each separate file type". Then it will remember a separate directory for models vs gcode files.
Thanks - that works! (on Mac, it's under Simplify3D > Preferences > General)
