[ADDED] Internal/External Support range feature
Posted: Tue Dec 02, 2014 11:08 pm
by aschwehr
I would like a feature that creates supports for a certain percentage or height range. For an example, if I have a part in which half is flat on the platform and the other half is raised 5 mm. Then there is an overhang on top. I would like to somehow have automatic supports for 0-5mm but nothing on top. I know I can manually remove supports, but this is impossible at times. Lets say I have a cylinder laying on its side. I would like external supports for the overhang but nothing internal. So an internal/external support may work too.
Re: Internal/External Support range feature
Posted: Thu Dec 04, 2014 10:34 am
by KeyboardWarrior
It sounds like you're having trouble clicking the internal regions of your part. One thing that might help is the cross-sectional view tool on the right-hand side of the program.
Posted: Thu Dec 04, 2014 7:34 pm
by aschwehr
Replicator G let me do this. It sure simplified things. I should have to use the cross section tool. It isn't easy to use.
Posted: Thu Dec 04, 2014 9:54 pm
by jimc
im not exactly sure what your part looks like but is this something you can use a 2nd process for? above 5mm turn supports off
Posted: Thu Jul 09, 2015 10:48 am
by S3D-Jason
Version 3.0 now has a new option to only add support structures if they are touching the build platform. This can be used to avoid support structures inside your part.
