[FIXED] no profile is loaded if you open an STL on the desktop
Posted: Wed Dec 28, 2022 3:48 pm
by perry4916
no profile is loaded if you open an STL on the desktop. (so it starts V5)
if you open V5 normally, then you will have a profile loaded.
Re: no profile is loaded if you open an STL on the desktop
Posted: Fri Dec 30, 2022 12:31 pm
by S3D-Jason
Are you saying that there's no processes in the list on the left? Was there already processes in that list when you last shut down the software?
Posted: Fri Dec 30, 2022 3:02 pm
by perry4916
correct.
When I start the program normally. there is a process on the left.
But when the program is closed and I double click on an STL so it will open the program , then there is no process, and i need to assign a new process again.
Posted: Tue Jan 03, 2023 4:40 pm
by S3D-Jason
Thanks for reporting this. I will be sure to share it with the team.
Did you by chance use V4 on this same computer? Does it have the same behavior?
Posted: Thu Jan 19, 2023 2:45 pm
by S3D-Jason
This was fixed in our latest Version 5.0.1 release. Please update to the latest version of the software and it should now behave better when launching the program using a STL file.
You can see all of the other changes here:
https://www.simplify3d.com/products/sim ... ase-notes/
