V5 not turning on part cooling fan on Duet3
Posted: Wed Dec 28, 2022 9:58 pm
by jwhils
Running Duet3 on a Railcore printer. Not having issues getting the part cooling fan to turn on at layer 3 with V4 (PLA). V5 isn't turning on the fan. The V5 gcode is adding a "P0" in the M106 command line. I have to assume Duet isn't recognizing it? Aside from editing the gcode, can the P0 be removed when slicing. I assume this is coming from the new "mounted vs. environmental" fan selection?
Re: V5 not turning on part cooling fan on Duet3
Posted: Fri Dec 30, 2022 12:35 pm
by S3D-Jason
You can probably remove the P0 part pretty easily if the Duet3 board has trouble with it. Go to Edit Process Settings > Scripts tab > Post Processing and add the following line:
{REPLACE " P0\n" "\n"}
That will remove the P0 part from the end of each M106 command.
Posted: Fri Dec 30, 2022 6:05 pm
by jwhils
Thank you. I will try this. Cheers!
