Glue-split part
Posted: Wed Dec 03, 2014 2:16 am
by oem
My parts have always been a size so they could be printed in one piece. Now I have a part I have to split and print in two prints and clue back together. Question what the best glue to use for PLA ?
Re: Glue-split part
Posted: Wed Dec 03, 2014 8:36 am
by dennisjm
Model glue works well I've heard but I haven't tried it much. I'm currently using super glue with an activator and it's bonding like they were the same plastic almost when done. Tried to take a piece apart the other day and I got breaking around the joint but the joint stayed fixed.
Re: Glue-split part
Posted: Wed Dec 03, 2014 10:34 am
by furicks
The best way to join 2 parts is not to glue them but to do a plastic weld. Take a soldering iron with a flat or chisel tip and use it to strategically melt the pieces together. The best irons for this job will have a digital temp control so you don't burn the plastic. However, you can do it with a cheap iron if you are careful.
I do this frequently to repair parts as well as join them together.
Re: Glue-split part
Posted: Wed Dec 03, 2014 12:00 pm
by Don
I use Loctite Control Gel Super Glue. It works great on PLA.
Here's an example of a design I did...
And it glued together with Super Glue
It's almost impossible to separate the glued parts. The print will break before the glued area does. If I've been handling the part a lot, I wipe it down with rubbing alcohol (same goes for painting a part) to get oil off it.
Re: Glue-split part
Posted: Wed Dec 03, 2014 1:02 pm
by dennisjm
Ha.. that's exactly the super glue I'm using. Yep works great.
