The French translation of V5 is poor... sometimes it looks like it was done with an automatic translator...
The V4 one was really better, despite the obsession to translate everything, even English terms that have become the standard in 3D printing technical discussions like for example "bed" ( Canadian automatic translator ?
in V5:
"support" is translate " les soutiens": nobody use that word...
"modèle d'importation" is not the same meaning that "importer des modéles"
"modèle de dépôt au lit"doesn't mean anything at all, nor does "drop the model on the bed". "Poser le modèle sur la table" from V4 was way better
ans so on...
Is it possible to open the access of the translation table, in order to make it a custom one ?
Do you accept advices about translation for a future update ? ( I did the french translation from "David Laser Scanner "a long while ago...)
I can, also, asked for help on french S3D forum to chose the better words
in the meantime I return to English version
Regards
