How about on this page....
https://www.simplify3d.com/products/sim ... /features/
You make it so I can click on Advanced Features and the like so I can find where they are?
Are the features automatic and there are no settings for them, or is a special unlock code to see more?
Documentation, Documentation, Documentation
With Documentation, you do not need to spend sooo much time handling support request.
Do me a favor and download and install ideaMaker. Import a model and then click "Start Slicing" at the top.
When you open the printing profiles you can hover over any settings text and it has a detailed "Tool Tip Text", if you click on it it will take you to a webpage that explains that setting. Copy them because they copied you. Only difference is their slicer sucks in comparison to yours.
Also, I am of the opinion that this setting:
https://marlinfw.org/docs/gcode/M221.html
Should be in the first layer settings because it works better than Extrusion width.
So I do not have to do this:
{REPLACE "; layer 1" "M221 S135 ; Set Flow to 135%\nM220 S100 ; Set Feedrate to 100%\n; layer 1"}
{REPLACE "; layer 2" "M221 S100 ; Set Flow to 100%\nM220 S125 ; Set Feedrate to 125%\n; layer 2"}
{STRIP ";"}
You have the best Slicer on the market and is worth the cost to use it, but please make it the "Best" Slicer on the market...
Please and Thank You,
/retnel
