blitzkneisser
[ADDED] Machine Control Panel supporting Klipper enabled printers
I am using the script workaround to save gcode files directly to the printer, having that supported natively would be a step forward - there's already a feature request open for that.
Next step would be to enable the Machine Control Panel also for Klipper printers. I can use the Web interface for monitoring and control - but having that feature available also in S3D would be handy. Can't be rocket science, other slicers are already supporting Moonraker
Re: Machine Control Panel supporting Klipper enabled printers
This feature was added in our latest Version 5.1 release. We now have full integration with Klipper powered printers so that you can connect to them through the normal Simplify3D Machine Control Panel. You can upload files, initiate prints, monitor the status of the printer, and pretty much everything else you can do with any other printer. It all happens wirelessly over WiFi and is quite convenient. Thanks for the great request!
You can read about other changes in Version 5.1 here:
https://www.simplify3d.com/products/sim ... rsion-5-1/
