Holograms
Posted: Sat Jan 14, 2023 5:31 am
by crashmaster
Anybody know why my model has these Holograms inside and outside of features?
Re: Holograms
Posted: Sat Jan 14, 2023 5:35 am
by crashmaster
Other areas of the print…
SOME BASIC SETTINGS:
2.5mm Retraction lift
0.12mm layer height
202 degrees Extruder temp
70 degrees bed temp
50 speed
POLYMAX PLA 1.75mm
Re: Holograms
Posted: Mon Jan 16, 2023 10:38 am
by S3D-Jason
That looks like ringing. There's an article about it here:
https://www.simplify3d.com/resources/pr ... d-ringing/
Re: Holograms
Posted: Tue Jan 17, 2023 7:08 am
by Thomasengelmann
Your print has a lot of issiues, but the problem you ate talking about is ghosting, your printer is vibrating. You can reduce the speed or acceleration or you can make the printer more sturdy
Re: Holograms
Posted: Wed Jan 18, 2023 8:40 am
by ptegler
yep..not slicer coding issue...that's a hardware settings issue. Acceleration is too high, belts are too loose, or trying to print too fast. You have to find the balance for your machines capabilities
ptegler
