siva
retracted moves crossing infill lines causing problems
My infill lines are not coming perfect and today while printing a larger part I noticed that there are certain non-print moves at the same place across layers and those are slightly disrupting the infill pattern with thin strings of filament. What can be done to avoid this?
Re: retracted moves crossing infill lines causing problems
you need to add z lift. in s3d is called "retraction vertical lift". usually one or two layer heights is sufficient
