[SOLVED] Configuration Assistant Connection Error 4.1.2
Posted: Thu Jan 19, 2023 10:43 am
by Njoro
I've been trying to login for the last 3 days but it's always the same, this only started after V5 launch...
Re: Configuration Assistant Connection Error 4.1.2
Posted: Thu Jan 26, 2023 7:51 am
by Njoro
"anyone on S3D support team"?
Posted: Mon Jan 30, 2023 9:48 am
by S3D-Jason
Sounds like the software isn't being allowed to access the internet. Might want to check your firewall or network settings. If you have a corporate proxy you also need to make sure you configure that using the Network Settings button.
Nothing has changed with V4, even after the V5 launch, so if this problem just started happening it must be related to something else like a change in the network.
Posted: Mon Jan 30, 2023 10:18 am
by Njoro
S3D-Jason wrote: Mon Jan 30, 2023 9:48 am Sounds like the software isn't being allowed to access the internet. Might want to check your firewall or network settings. If you have a corporate proxy you also need to make sure you configure that using the Network Settings button.
Thanks Jason, for some reason the App had the network connection changed to "Manual Connection" which does have an IP address which is the same a the PC address.
I changed it to "Auto" and also made sure it's not blocked by the firewall....
All good now..
