It would be beneficial to specify the top layer heights when using Adaptive Layer Heights.
The issue is that when using bigger layer heights, the top layers that bridge across the infill don't look as nice. It almost looks as if it's not able to bridge across the infill lines as well.
It may just be that it takes more layers to make the top surface look nice, but the number of top layers required vary based on the layer height. Being able to have the same layer height for the top layers every time would be more beneficial.
