Command Line 3D Printing
Posted: Fri Jan 27, 2023 3:47 pm
by Damani2
Hello!
I'm looking for a way to utilize command line to send models from Autodesk Meshmixer straight to simplify 3D. Meshmixer has a tool that should work, but I'm not exactly sure how to set it up. Can anyone here advise me?
https://help.autodesk.com/view/MSHMXR/2 ... 6CF1DF8CB3
Re: Command Line 3D Printing
Posted: Mon Jan 30, 2023 9:59 am
by S3D-Jason
What operating system are you using? It looks like you just need to define the complete filepath to your Simplify3D installation.
Posted: Fri Feb 03, 2023 12:46 pm
by Damani2
Awesome! I'm running Windows 11 Pro and the latest version of Simplify 3D v 5.0.1
Can you give me example of how the fields should be populated?
Posted: Fri Feb 03, 2023 5:09 pm
by S3D-Jason
For the "Printer software name" field use either "Simplify3D" or "Simplify3D.exe" (not sure which)
For the "Printer software path" use "C:\Program Files\Simplify3D-5.0.1\Simplify3D.exe"
Posted: Sun Feb 05, 2023 2:13 pm
by Damani2
Yea it's not working. It's able to launch simplify 3D but then the software says successfully imported factory file with 0 models. So it's not bringing the model in for some reason. Any ideas? Maybe there's something with the command line field?
Posted: Wed Feb 15, 2023 10:27 am
by Damani2
Update on this. It works with Cura. So it's an issue specific to Simplify3D. Would be cool to have this feature maybe in the future.
