Recently purchased and upgrade 2 licenses for S3D 5 and running 5.0.1 now
I have found that when I re slice and try to print one of my original factory files that has 12 models printed sequentially through SD card my printer reboots as soon as I select the file.
The S3D 5 sliced file generates 3000+ lines of meta data at the start of the file (commented out slicer settings)
Comparing to my saved S3D 4 slices of the same file it will generate only around 200 lines!
Looking through that 3000+ lines of slicer settings I can see that not only does S3D have a lot more meta data, the entire list of slicer settings are repeated for every model that's going to be printed!
If I delete 1000 lines of this meta data from the start of the file before printing it works fine.
This tells me the printer is running up against a memory or buffer limit and crashing while searching for the start of the GCODE
S3D Team, please comment on this and explain how to either reduce the meta data being added to the GCODE file to prevent the crashing on ender3s or offer a software update to fix this!
Thanks
