GuyGuy
[ADDED] Creates gcode thumbnails
Hello,
Creates gcode thumbnails from Simplify3D within Windows 11 environment for Klipper.
A solution please?
Re: Creates gcode thumbnails
I think this was already requested in another thread:
viewtopic.php?t=16689
GuyGuy
Yes, but no solution. Maybe in a future update?
If in the process, you could also add the following information so that it also appears in Mainsail
Length of filament used
Printing time
Extrude temperature
Tray temperature
I bet it is already possible to get print time, filament length, etc to display in Mainsail. You just need to add the correct comments in your S3D script.
Can you post a file that DOES already display the correct statistics? That will be easy to look through to see what comments you need to add in S3D.
We added the ability to embed thumbnail images into the gcode with Version 5.1. You can choose between many different formats and resolutions so it works well with your printer. I posted instructions for Klipper here:
viewtopic.php?p=65524#p65524
