Damani2
Printer Build Volume Boundary Offset
This is a small issue - but the printer build volume visualization doesn't respect the offset values that I set in the Global Offsets under the output tab. So basically it shoes my buildplate cutting through the print and I can't see the brim layers. This would be an easy fix in an update.
Re: Printer Build Volume Boundary Offset
I don't think those values are supposed to move the build platform. The global offsets instead move the values in the build files, so when you load a preview you will notice all of those movements are shifted relative to the bed (but the bed remains stationary).
If you want to move the bed, you should use the origin offsets instead.
