Snap surface of model A to center of selected surface on Model B
Posted: Tue Feb 07, 2023 9:51 pm
by RetroDesign3D
Like Autodesk123D (old) and Fusion360 where you can select a surface of one model, then select a surface on another model and the First model will snap centered to the Surface of the second model.
Simplyfy3D already does this to the build plate, we just need an option to select a second surface to perform this on instead of the build plate. This will make assembling scenes to print so much easier if we could do this in slicer.
Thank you
Re: Snap surface of model A to center of selected surface on Model B
Posted: Tue Feb 07, 2023 10:00 pm
by billyd
Yes good idea. Also a good way to reconnect models that were broken up purposefully and you want to make whole again so the software could orient the two mating surfaces perfectly prior to joining (assuming they were once directly connected at those surfaces).
Posted: Tue Feb 07, 2023 10:47 pm
by DrD
RetroDesign3D wrote: ↑Tue Feb 07, 2023 9:51 pm
Thank you
In the meantime, as a suggestion, you could use Autodesk's Netfabb. It'll allow you to stack models and so much more.
I use it for model placement/repairs where S3D is lacking.
D.
Posted: Wed Feb 08, 2023 2:53 pm
by S3D-Jason
Interesting idea! Can you link to a quick video or GIF showing the snapping operation? I'm interested to see what you mean by always snapping to the center. I imagine that for many parts that wouldn't be enough to fully align them, although I guess it would work for many cylindrical parts.
Posted: Fri Feb 10, 2023 7:15 am
by RetroDesign3D
26 seconds mark to 33 second mark shows a simple snap.. there are more examples if you watch all 3 min. video
https://youtu.be/_ioedS55GU0
sorry I dont know a thing about making gifs
Posted: Fri Feb 10, 2023 11:55 am
by S3D-Jason
That's perfect. Very helpful!
