Change Rotation Resets To "0" After Arrange
Posted: Tue Feb 14, 2023 5:44 pm
by wirlybird
When you take a part and rotate it on the build plate then click on "Arrange" it resets the value you entered for rotation to "0" rather than leaving the value you set in the numerical selector box.
This is very inconvenient if you are testing how many degrees you need to rotate a part.
So, if I rotate a part 40 degrees then hit arrange then go back to rotate more the value in the selector box is now "0" rather than "40".
I have seen others mentioning similar issues with scaling.
I think we really need to leave the values entered alone as they represent the change from the original position or size.
Re: Change Rotation Resets To "0" After Arrange
Posted: Wed Mar 01, 2023 6:06 am
by bolsoncerrado
Yes, this is a BIG issue along with the scale one :(
Posted: Thu Mar 02, 2023 8:03 am
by RetroDesign3D
all translations seem to reset to 0.
Posted: Fri Mar 03, 2023 7:12 pm
by jfkansas
bolsoncerrado wrote: ↑Wed Mar 01, 2023 6:06 am Yes, this is a BIG issue along with the scale one :(
Must not be that big to them....
