Sonic Pad and BamBuLab connectability
Posted: Fri Feb 17, 2023 5:28 pm
by rceagle1
Please work on getting the ability to access the Creality Sonic Pad, as well as direct communication to the BamBuLab X1C and P1P being able to retain the Lidar calibrations on the X1C
Re: Sonic Pad and BamBuLab connectability
Posted: Sun Mar 19, 2023 8:24 am
by ampster
What do you mean by access to the Sonic Pad? You can send files to the Sonic Pad from S3D now, is there something else you'd like to see?
Posted: Fri Mar 24, 2023 7:58 pm
by Monty3DP
Please how can you send files directly to the sonicpad and also retain the preview.
I can't find instructions to set this up
Re: Feature request: Sonic Pad and BamBuLab connectability
Posted: Thu Apr 13, 2023 12:44 pm
by Wolf6660
I'm also interested, how to automatically load the gcode onto the SonicPad.
Posted: Tue Apr 25, 2023 12:03 pm
by juergen-t
Posted: Wed Apr 26, 2023 8:58 pm
by ampster
Wolf6660 wrote: ↑Thu Apr 13, 2023 12:44 pm Hi,
many posts here describe how to do so following instructions for octoprint. You will not get the gcode preview however.
viewtopic.php?p=63841#p63841
viewtopic.php?p=64614#p64614
viewtopic.php?p=65106#p65106
viewtopic.php?p=65115#p65115
Posted: Thu May 11, 2023 11:51 am
by S3D-Jason
Version 5.1 added direct WiFi connection capabilities for the Sonic Pad. We have one in our office that we have been using extensively and it is working great. You can read about all the other features in Version 5.1 here:
https://www.simplify3d.com/products/sim ... rsion-5-1/
We'd be happy to look at adding support for the BambuLab printers in the future. Thus far we haven't seen much documentation for those APIs, so please let us know if there's any information that could assist with the effort.
Posted: Thu May 11, 2023 12:11 pm
by blitzkneisser
How is the connection to the Sonic Pad established? The Machine Control configuration looks the same as in 5.0.2 - and I can't connect my Sonmic pad no matter which Port I try
Posted: Thu May 11, 2023 12:17 pm
by S3D-Jason
We provide some suggestions on what port numbers to use here:
https://www.simplify3d.com/resources/faq/#quest-6354
For the Sonic Pad, it should be port 80 since it is Klipper based. Creality may not have the zeroconf discovery module enabled by default (meaning S3D cannot detect the IP address on it's own), but you can go into the network settings on the Sonic Pad to see the IP address and then enter that into Simplify3D manually. At that point it should be able to connect. If you're still having trouble, it might be good to make a dedicated thread on the troubleshooting subforum or email our team directly for help.
